Engine: F150TLRC (2004 four stroke), PTT assembly 63P-43800-00-00, 3 ram SHOWA. The main valve arrangement in the oil pump uses (4) tiny check balls. The upper and lower check balls have different part numbers: upper 64E-43858-00-00, lower 72X-43858-00-00. These are items 18 and 7 in the diagram. What is the dimensional difference? Are they interchangeable? Thank you boscoe99 for the image.
