Wondering if there is a kill switch that can be bought without having to use the lanyard type kill switch. I know other manufactures use just a push button type of kill switch. If there isn't can someone explain my problem? If I use my old clip on the motor I can push the red button to turn the motor off but I had to purchase a new clip due to the old one starting to wear. Now with the new clip I am unable to push the red button in to shut the motor off the only way to shut the motor off is to pull the clip.
Kill switch
Sounds like the wrong lanyard is being used.
But now if you are asking if another push button kill switch can be added, then absolutely positively. Just get a normally open momentarily closed switch and wire it to the existing switch.
What is the complete model identity of your motor? Different motors may use different kill switch lanyards.
With the clip in place, 'should' you be able to still push the red button to kill the engine? Granted, I haven't seen every single type of kill switch there is, but with all of the ones I've seen, once the clip is on it prevents the button from being pushed. Isn't that the purpose of the clip - to keep the button from being pushed? Maybe your old clip was, as you mentioned, worn and allowed that to happen?
Doesn't your motor have another "off" button somewhere?
Like I mentioned, I could very well be wrong with my line of thinking, but I'm curious to here about this.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Originally posted by DennisG01 View PostWith the clip in place, 'should' you be able to still push the red button to kill the engine? Granted, I haven't seen every single type of kill switch there is, but with all of the ones I've seen, once the clip is on it prevents the button from being pushed. Isn't that the purpose of the clip - to keep the button from being pushed? Maybe your old clip was, as you mentioned, worn and allowed that to happen?
Originally posted by boscoe99 View PostSome Yams use a combination switch. With the lanyard installed then pushing the button in, even with the lanyard attached, will kill the motor. I am guessing this is what the OP has.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Thanks for all the replies. I will be looking into possibly finding/ordering a different kill switch. I am thinking of one that does not have to use the lanyard. I just don't like the lanyard. Doesn't anyone recommend what type to order or where to order one from that does not require a lanyard.
How can anyone suggest a non-standard switch when it is unknown what brand or model of motor that you have?
Now a switch is going to be much more expensive than simply getting the correct lanyard. And when you get thrown out of the boat the motor will keep running. The boat will go into auto-circle until it can find and run you down.
Keep a note of good bye somewhere for those that you leave behind. They will appreciate it.
Originally posted by boscoe99 View PostSounds like the wrong lanyard is being used.
The model number is 25sk
Does that help?
Does that help?
1985 25SK Yamaha Outboard Parts
Part 5 is your current kill switch;
http://www.boats.net/parts/search/Ya...IES/parts.html
I don't know why you couldn't simply wire in a Marine toggle switch in place of the factory switch.. A simple on/off...Last edited by TownsendsFJR1300; 09-13-2015, 07:39 PM.Scott
1985 25SK Yamaha Outboard OPTIONAL PARTS SWITCH PANEL-RIGGING ACCESSORIES Diagram and Parts
So, back to my sarcasm that was intended to get a point across, if someone decides to remove the kill switch and lanyard.
"Keep a note of good bye somewhere for those that you leave behind. They will appreciate it."
And if you decide to wear your vest then they will be able to find the body.
Originally posted by boscoe99 View PostYou could. But then you would not have a device that stops the motor if you get thrown from the boat.
BUT, the OP wants a simple, NON-safety switch.
He re-iterated that in response to your post. He apparently knows the ramifications.. The above should work for his wishes...Scott
Originally posted by TownsendsFJR1300 View PostI read all of that... And I agree,.
Too much lawyer stuff going on now a days, be careful
I think the OP changed his mind about wanting a simple on/off switch after he thought about it a bit. Maybe my sarcasm helped.
"I will get the model number off the motor this weekend and post it so that you will be able to help me out. Thanks for the sarcasm in your response I really enjoyed it."
ÂÂ
