The motor will not trim/tilt up. Boat is in the water. I used the release screw and was able to get the motor up. The trim motor sounds fine and no oil slick around the pistons. The two trim pistons are still fully recessed so unable to check for fluid level. Can anyone give me some advise on what to do next? Is there a way to get the two trim pistons to manually extend?
