Mistery loose part inside engine bottom cowling
  • Mistery loose part inside engine bottom cowling
    I just found this part floating around my engine bottom cowlling, found it where the rigging grommet and the shift cables are inside of the cowling, dont know if came from some other place or not since i tilt the engine all the way up for storage. Can you somebody give me some tips of where this might have come from. 20220828_174134_79.jpg
    sorry for the double post
    by the way the engine is a 2018 F90LB
      looks like a cable hold down to me
        question is from where
          View the parts catalog.
            that was the first thing i did, looked in the bottom cowling 2 diagrams and i could not see anything to that sort, i even looked in some other diagrams, but no luck ;(
              It's just a cable clamp. Hard to tell the size from the picture, but the size of the clamp generally matches (sort of) up to the size of the wire/cable/hose. Somewhere there is a bolt, as well. OR.... it's been there for a long time because someone dropped it, couldn't get it, and just used another clamp.
              I would assume that you've given the engine a good once over and nothing seems out of place, right? In that case, I wouldn't worry too much about it. But if you want, look for a matching size wire/cable/hose and a female thread/hole that is missing it's bolt. Forget about the diagrams - just look on your engine.
                I agree with this….the clamp may have been in there since coming from the factory….
                  Well i will definitely take a hard look in the engine, i am very picky when it comes to the engine. Thank you for the recommendation
