'04 115 two stroke, this is my fourth season with this engine, will idle in gear smoothly around 750-800, but try 1100-1250 and she shakes. Rattles T-top. 1400 and smooth.
I've cleaned the carbs each winter, and used factory manual 18616-02-72 to link and synch.
Otherwise the engine is quick to plane, propped for 5500, fuel and oil use seem normal.
I'm guessing problem occurs when transitioning off idle circuit, has anyone else seen this?
The paper manual I have is for C models, could the link procedure be different?
