I don't think this is a common problem. I can't find any info on it because searching for anything about alarms just leads to a bunch of people talking about overheating engines.
I'm trying to get my alarm to work on my f50. I've tried cranking it with the safety lanyard removed and no sound. I took the buzzer out of the control box and gave it power and it worked. I reinstalled the buzzer and removed the wires from what looks like a temp sensor on the rear of the motor and plugged the wires together and started the engine. No buzzer. Side sensor, same.
There is +12v at the yellow wire on one side of the buzzer. The other side is a pink wire that goes through the harness through the big connector and I think to the CDI box. I poked into the pink wire and connected it to ground with the key on and the buzzer sounded. Am I correct in thinking the CDI box is what controls the alarm? Thanks for any input you may have. J
