Went to tilt my 9.9 for the first time this year and nothing. Tried to start it and all I get is a click when I push the start button. My main motor tilts and starts just fine. Ended up removing my batteries and installing a new one. Same issue. I'm getting power to the 9.9 but it doesnt want to do anything.
9.9 2015 4 stroke all locked up
take a look here and then tell us which of those 2015 4 stroke motors yours might be.
Yamaha - Outboard - 9.9HP OEM Parts | Boats.net
also, since you just get a click like a dead battery, I would be checking all connections to make sure they are clean and tight.
And monitor the voltage going into and out of the start relay
cables can go bad too
When I say locked up I was referring to neither start or trim was working and not the crank shaft. I will double check that though. Thanks for the help on this. Kind of at a loss. With a new battery installed I still have the issue. My main motor works just fine but my 9.9 doesnt want to do anything. I can here the relays clicking, checked for power at the motor and it has juice.
Originally posted by FishnFool View PostWhen I say locked up I was referring to neither start or trim was working and not the crank shaft. I will double check that though. Thanks for the help on this. Kind of at a loss. With a new battery installed I still have the issue. My main motor works just fine but my 9.9 doesnt want to do anything. I can here the relays clicking, checked for power at the motor and it has juice.
Originally posted by FishnFool View PostWent to tilt my 9.9 for the first time this year and nothing. Tried to start it and all I get is a click when I push the start button. My main motor tilts and starts just fine. Ended up removing my batteries and installing a new one. Same issue. I'm getting power to the 9.9 but it doesnt want to do anything.
The cables can look perfectly good on the outside and be full of corrosion on the inside...
Just went through this exact same issue with my brothers boat...rotten cables that looked fine.
Best of luck
Well apparently on my model if the motor is tilted up it won't start. Ended up finding out my tilt motor got water inside it and corroded over the winter. Tilt motor shorting out so it wouldn't move down. There is a screw on the bottom of the motor that frees it up so you can drop it. Once it was down it let me start my motor. Now in the process of rebuilding my tilt motor and should be good. Lesson learned. Thanks for all the help!!
Originally posted by FishnFool View PostWell apparently on my model if the motor is tilted up it won't start. Ended up finding out my tilt motor got water inside it and corroded over the winter. Tilt motor shorting out so it wouldn't move down. There is a screw on the bottom of the motor that frees it up so you can drop it. Once it was down it let me start my motor. Now in the process of rebuilding my tilt motor and should be good. Lesson learned. Thanks for all the help!!
thanks for reporting back what the problem was
