Almost any standard tachometer will work with your motor.
If you use a Yamaha multi-function tachometer then some of the features on the tachometer may simply not be usable. The oil status system for example. The check engine function for example. The water in fuel warning for example.
Your motor only has one warning feature. That being for over temperature. So, if you hear the warning horn you will know what it is for. You don't need a light on a tachometer to remind you.
Why not just get the cheapest, plainest, simplest tachometer available and install it. Or, just go without a tachometer.
Now if you are looking for a data base that shows all tachometers known to man, and of those tachometers which will work with your motor, and which features of said tachometers will be usable for you, then good luck. There is no such data base available. It would take time and money to create same. It would have nil practical value.
But if you care to develop such a data base we would like to see it.
