my 70 hp Yamaha went in safe mode for low oil I filled it back up but it is still in safe mode how do I get it out of safe mode now, thanks
70 hp yamaha in safe mode
Originally posted by 99yam40 View Postwhen the condition goes away the RPM reduction goes away
You need to start looking for what is calling for the RPM reduction and alarm to be sounding.
Do you have gauges that are still indicating what problem is sounding the alarm?
I would think if the gauges showed a oil level problem and when you disconnected it the alarm went away, then the level switch is the problem.
Not a good idea to pull the oil level switch without draining the tank 1st, lets stuff on the bottom of tank get into the oil system plugging things up.
need to make sure the strainer is back in place or replace it when reinstalling.
Kind of sounds like you have a failed alarm buzzer also if it was not sounding alaon with the gauges not indicating properlyLast edited by 99yam40; 08-19-2015, 04:32 PM.
ÂÂÂÂ
