Hello everyone, I’m new to this forum.
I have a Yamaha 200 ox66 (sx200txrz).
the motor has a LOT of Trouble getting the boat on plane. If I’m going against the waves, it won’t plane. Prop is not too big. I can only do about 3/4 throttle otherwise it bogs down. Idle is a little rough. It had some water in the fuel and I’ve done the following
I have:
-cleaned, adjusted and changed all seals on the injectors.
-cleaned vst tank
-replaced vst filter
-replaced Low pressure fuel pumps
-replaced element filter next to motor
-motor is running on 5gal tank with known rec fuel. (To eliminate bad gas)
the problem is still going on.. doesn’t seem to be fuel related. Any ideas ?
+ More Options
I have:
-cleaned vst tank
+ More Options
