Bought my first prop to replace the original ate-up one on my T60.
It was one that required a hub. "Dealer" said "these hubs are for all Yahamas".
Got it home, started changing it out, sure seemed like it was made for a bigger shaft. So, I took it back and after having to explain in detail at least 3 times over the 'dealer' put me on the phone with a mechanic, who had to look it up! "Ahh", says he, there are 2 different hubs. One for over, iirc, 225(?) and one for under.
So I get the correct kit and install it.
The brass washer that goes on just before the castle nut is bigger that the shaft. Torquing down the castle nut causes the washer to be off-center. Is that going to cause an off-balance problem with the prop? Everything else fits with precision, this thick washer just seems wrong.
