F150 loss power after few minutes
  • F150 loss power after few minutes
    Hi friends
    I have an F150 2007 with 150 hours use only .
    The problem is this ; When I start the motor everything run ok but after some minutes I see that rotation decrease and cannot reach more than 4500rpm anymore .
    I already change all filters , clean the VSP , clean all injectors .
    My opinion in the electric motor of the fuel pump .What you think ?
    Any suggestion will be appreciate.
    Thank you
    Monitoring fuel pressures will tell you if there is a problem with pressures and where
      Loss of fuel pressure, possible restriction , pressure regulator, gas tank vent, gas line restriction ? some items to look at. Run on portable tank, measure fuel pressure
        stand 5 feet back.
        throw wads of cash at it.
        or trouble shoot it.
