Yamaha boat motors
  • Yamaha boat motors
    I have a 1997 115 h.p. V-4 two stroke, it runs up 2 1.600r.p.m. If u ask it 4 more throttle it dies. Starts fine& idle fine. Thank you
    Welcome aboard G&H.
    Always post your complete model #,
    as that tells everyone exactly what motor you have
    You have not asked a question yet and are using texting language it seems.
    Some of us older folks may not catch on completely, but I guess you should be monitoring the fuel pressures to see what is happening at the failure RPM
      Notwithstanding 99yam40, it appears your motor is in limp mode, won't allow you to rev more. Usual problem is overheating , but also other causes. Your buzzer alarm should also be sounding if this is the case.
        Good thought , need to test alarm system to make sure it sounds when it should.
        But it should get to 2k before limiting on most motors
