2 stroke got hot! 40hp Nissan. It bogged down and died. Almost sized up when I tried to restart it. It’s free now. I got 125psi on the top hole and 35 on the bottom. I haven’t pulled the head yet, but looked at both cylinders with a camera. So scoring and piston looks ok, but no metal on the plug or in the cylinder. I was assuming rings but could a head gasket cause that much compression loss. Looking at it with the camera inside the cylinder I can see part of the head gasket missing I think. Any help before I tear into it would be very appreciated. Thanks
2 stroke low compression
pull the head to see what the gasket looks like.
if combustion gases are blowing into the cooling water cavities, that would cause a cooling problem
Thanks guys. I think it was a ring that got stuck from getting hot. I ran it to try to figure out where and why it was getting hot. Faulty thermostat was the culprit. In the process of running it, the compression is now up to 120 again. Fixed but not sure how LOL.
Originally posted by Johnnyb1980 View PostIt ran ok at low rpm but gets hot and dies after 5 mins of full open on the water. Checked thermostat and its working and water is flowing. Not sure what caused it to get hot to begin with. Any and all ideas I’ll be thankful for. I’m new to outboards and this forum. Thanks
good to hear it is back to normal
ÂÂÂÂÂÂ
