Shift shaft detent ,lf225txrc
  • Shift shaft detent ,lf225txrc
    Port motor stuck in gear, I just knew it was lower unit, long story short, lower unit was fine, could not move shift @ the motor . Pulled the power head on Saturday, rusty spring and ball bearing in detent , total b/s no way to lube, replaced shift shaft as it was buggered up at the top, also replaced oil pump since I had it apart, cleaned and lubed everything , put everything back together,put 34 venture back in water by 6 pm , long day , If I meet the guy who designed the three bolts on the rear of the power head ( center) I think I will not buy him a drink, may even spit in his drink , they are a pia
    They are if a regular wrench is used.
    Use these bad boys and it is a piece of cake.
    http://upceansearch.com/upc/099575854903
    GearWrench JUMBO Locking XL Flex Wrenches — 12-Pc. Metric Set, Model# EHT85698 | Flex Ratcheting Wrenches| Northern Tool + Equipment
      Dang more good stuff to buy
        my 14mm gearwrench died a few days ago.
        I still have 3 F350 powerheads to pull and now another F250 powerhead.
          There is no such thing as having too many tools.
          Buy a new tool and then find a use for it.
            tools are like rifles.
            you simply cant have to many .
