50 pro will not start
  • 50 pro will not start
    91 pro,50 oil injection
    Good compression 150 all three cylinders
    Fuel ball solid
    Good spark
    Fuel to side of carbs all three
    Runs if I spray fuel into carbs but will not start
    Help!,
    Clean the carbs
      Ditto. was it running before? Anything change since? Anyone change any of the carb settings etc?
        +1 on cleaning the carbs.
        Did you let it sit for any length of time W/O fuel stabilizer? It doesn't take much for varnish to build up in the jets.
        Once you get it cleaned out and running, use a stabilizer(if not already) and also Yamaha's "RingFree". It helps keep the fuel system clean as well as the top end. Works, really, really good.. It'll be the last time you clean the carbs..
