I have a 2003 200hp hpdi and i have been trying to trouble shoot it. The service manual i have says to measure the crank position sensor and the injector driver's peak voltage. Does my multimeter need to be in ac or dc? When I tried to test it in ac i get a reading and it shuts the motor off. Is that normal?
2003 200hp hpdi trouble shooting question
You will need to set your multi-meter to DC, do you have a peak voltage adapter? if not you can't measure peak voltage (some multi-meters have it built in)
http://www.amazon.com/CDI-Electronic.../dp/B001O4TZGGLast edited by greasyshaft; 07-04-2015, 10:19 PM.
