On a 05 F150 TLRD, to hook up a Temperature Gauge will the existing sending uint and wiring harness work or will I need to add on and or change out current sending unit going to my tach.
Temp gauge
While your F150 has a temperature sensor it does not provide information to the tachometer. It provides information to the ECU.
A sensor cannot normally support two devices at one time. So, you cannot tap into your existing sensor.
In the case of your motor you can add an independent temperature gauge with a compatible sender if you wish.
Your tachometer does not get a signal from the thermosensor. It gets a signal from a thermoswitch. That switch, when it is grounded, causes a light to illuminate or an icon to start flashing on a Yamaha tachometer.
Here is a link to a Yamaha temperature gauge and sender.
2015_Yamaha_MRP
2015_Yamaha_MRP
ÂÂ
