I have a 03 Z300 TXRC. Within a couple of seconds of turning on the warning horn goes off and I am in limp mode. I do not have the digital gauge however I do have the diag software. I see no issues in the diag report.
I disconnected the temp sensor and the warning horn comes on immediately. So I do not think this is the issue. My next best guess is the Oil senders on the remote or engine tank.
The oil override switch does work and I hear the engine oil pump running for a few secs when I turn the ignition to start.
I did replace my battery cables with new marine grade ends and purchased two new AGM 880CCA with reserve. The motor cranks right up.
I was going to drain the engine oil tank to verify that it fills it back up. Also change the oil filters at the remote and engine.
I just got this boat so I am not familiar with its rigging yet. I started with the batteries to make sure I got good power.
The motor has 423 Hrs on it.
Any other suggestions?
