I bought this Mako 261 a couple of days ago. There are no ID tags on either engine. The engine cowls say Saltwater 2 and 200Hp and engines and carbureted. All help appreciated
At least the 6K1 prefix can be seen on the data plate. That is a good start as it provides a clue to the engine family. Now if you can provide the serial number we can get to the model identity.
Look on the block, in the vicinity of the starter motor for a round decal. It will be black with a white bar in the middle. In that bar are some numbers. What are they?
Thanks Boscoe, Im away from the boat for a few days but do have the following pics on my PC. The gauges may give a clue and the ECU has the following numbers on it CU7682 and D1 1130.
