Got this boat on Friday. 5 minutes after putting in water the overheat alarm sounded. Shut motor off. No water coming from pee hole so removed lower end and replaced water pump-entire kit. The impeller had nothing left for vanes. Removed all the broken impeller pieces from pump. Also found a lot of impeller pieces behind the water intake screens on skeg. Cleaned all out. Reassembled pump and re-installed lower end.
No water from pee hole unless running at 1500+ RPM. Motor still sounds overheat alarm.
Checked thermostat--all good. Removed and inspected pressure control valve. Looked okay-just a spring and plastic valve.
Ran motor with water house connected to flush port. Plenty of water through pee hole and motor does NOT overheat or sound alarm if water is forced through using the flush connection.
Remove flush connection and back to original problem.
This motor has 95 hours on it. What else needs to be checked or could prevent water from properly circulating through the motor? Is there a diagnostic flow chart to troubleshoot such problems?
