1989 115ETLF. Starts idles, backfires through exhaust, appears to run on only 2 cylinders, spark at all 4 plugs, spark at coils.
1989 Yahama 115ETLF running problems
thank you
plug wires seem to be on correctwill check fly wheel key. I am in questionas to coil wire connections trying to find cylinder numbers, coils wires are numbered and little as I know it appears two bottom might be crossed.
Did you (or anyone else) do ANYTHING to the engine before the issue?Scott
ÂÂÂÂÂÂÂÂÂ
