Hi all,
having an issue with a 2014 Yamaha f150. The engine has about 600hrs ram great all season. Currently everything is good idle is right where it should be. Accelerates good. When I get up on plane I’ll run between 4000-4500 rpms after about 5mins of run time I get a big power loss, the rpms drop from the 4500 range and fluctuate between 2500-3500 the engine never stalls though . I initially thought this might be a fuel problem and my lift pump was bad but I have literally ruled out every part of the fuel system from the tank to the injectors and it still does the same thing. Anyone have any ideas ?
