I've been working on a 1987 Yamaha 90 outboard a customer brought in saying he wanted the carbs cleaned do to it not running right. He insisted it was the carbs. I cleaned the carbs took out to test and still wouldn't run correctly. Brought back to shop and tested compression. Had compression on all 3 cylinders. Tested the spark and there was NO SPARK on cylinder 3. Swapped #2 and #3 coil pack and still no spark on #3. Purchased brand new CDI and tested. Now I have spark on Cylinder #2 and #3 but NO SPARK on cylinder #1. Figured it was a faulty CDI, so tried a different one. Same result NO SPARK on #1. Changed back to original CDI and back to NO SPARK on #3.
Any help with this issue would be greatly appreciated, as I am stumped as to what it could be.
Thank you
Thank you
