11998 150 Saltwater series II trim switch mystery
  • 11998 150 Saltwater series II trim switch mystery
    Hello all!
    My son and I own a 1998 Hewes 19 bay fisher with a Yamaha 150 saltwater series II.
    The trim button on the throttle will trim up but not down. The switch on the motor works fine in both directions, so I assume the motor pump and hydraulics are OK.
    Last weekend,we removed and replaced the throttle switch with a new one purchased at a local dealer. After installing (without routing the wires) the problem still exists. No change.
    After study, I'll admit I'm stuck. Any advice on where to look next?
    Is there a schematic available anywhere?
    Many thanks in advance for your advice.
    wire. connections between the switch and relay would be my thought
      +1^^^^. Has to be.
      Simply follow the wires or even easier check the continuity of them and where they connect..
