$20 apiece lower case bolts?
  • $20 apiece lower case bolts?
    Hello,
    Why do the 6 bolts that secure the upper case to the lower case cost $20 per bolt? Has anyone a less expensive substitute that worked for them? When I disassembled mine it was missing 2 on the port engine. Also missing was the longer bolt that is accessed once the trim tab is removed.
    Personally, I wouldn't hesitate to use SS bolts. If you don't already know the sizes, just take them to a local hardware store and match them up. Put some Tef-Gel or Mercury's Perfect Seal (or similar) on the threads and you're good to go.
      Do you know if the stock bolts are an alloy or stainless?
        I believe they’re some kind of stainless/alloy….since mine do discolor some in salt water….I would’nt hesitate to use some good hardware store stainless steel bolts….Ace Hardware carries a good selection of nuts, bolts, fasteners, etc…
          I don't know, offhand - possibly it's dependent on what year/model you have, as well? But it doesn't matter - SS is fine.
          However, you should be able tell by the weight of the bolt in your hand.
            I thought SS was an alloy of metals
              They're 20 bucks because when mechanics work on your boat they generally use Yam parts and Yam says so. If you want to dig even deeper, why does a 1/8 inch diameter, 4-inch piece of fuel line cost 70 bucks? A ninety-degree bend costs 69 dollars. It's nuts.
                Ace is the place. A couple of bucks apiece.
