I am having trouble fuel fouling plugs after only a few minutes of running on plane. Runs all day at low rpm but when get on plane plugs foul. Pull them and they are full of gas. Put new ones in and runs great till get on plane and aftter few minutes they foul out again. All four plugs seem to be fouling. Anyone have this problem before?
03 f115
I suspect that you really want to know what may be causing your problem and not just if anyone else has had this specific problem before. Correct or ???
I personally have not ever had the problem you are reporting.
What is your fuel pressure at idle and at the RPM setting where the problem occurs?
Have the injectors ever been cleaned?
The motor is not burning/using oil correct?
Has the compression been checked (direct and/or differential) and, if so, what values were seen?
