When I winterized my 1988 Yamaha 130hp V4 it was running great. Pulled it out of storage and there is no spark on any of the 4 spark plugs.
The rectifier/regulator failed a resistance test and I have order a new one. The stator passes the resistance test however when cranking it over I get no voltage readings as per the service manual. Would a bad stator or CDI be the likely culprit?
Should I change the pulser coil assembly too?
Thanks.
Thanks.
