Lost key
  • Lost key
    Ok I losty only Yamaha key. How can I get a replacement is there a code to the key . I have console mount key ignition.
    Code is on the key. It is also on the key switch. You might have to remove the bezel that holds the switch in place to find the code number.
    Then, order the key, or two or three, from boats.net
    2015_Yamaha_MRP
      Thanks I will check it out .
