Like mentioned, I have 1996 (?) 25QEO, deristricted to full 40 hp, its loosing power when gets warm. On wot and cruising speed, it slowly slows down, till i'm not planning anymore. If i shut it off, pump it ( prime it) the pump feels full, it starts from first two turns, then for a minute or two runs ok again, then again starts to slow down.
Carbs have been taken apart and cleaned, filter/water separator removed and hose from the gas tank put directly to the fuel pump.
The fuel line has been put directly to the gas in the tank ( eliminating bad fuel snorkel line and its connector).
What else I can do?
Any advice apriciated....
Kind regards.
What else I can do?
Kind regards.
