Hpdi 200 2001
  • Hpdi 200 2001
    The diagnosis tell me I have a bad injector in cylinder number 3.
    How do I know which is cylinder number 3? Please advise how i numbering the cylinders/injectors ?
    From the rear of the motor looking forward it is
    2 1
    4 3
    6 5
    With the motor running disconnect the connector to the number three injector. What does the motor do then?
      Is there a special reason why I should disconnect the injector when running? What should happen normally?
        RPM should drop if it was working properly before you unplugged it
          Problem fixed
          The rpm was not affected by disconnecting ejector number 3.
          Replaced the ejector and the engine is running smooth
