Am I okay with a 19 pitch prop WOT at 5K rpm on my 19’ Bayrunner Baja 2001 Yamaha F115 or should I reprop? Max water speed is 40 mph which is really too fast for this old man .
I know not what to say as to why you are not able to push that prop unless the motor , boat, or set up has a problem.
Maybe the boat is different enough in weight or hull design.
Yamaha makes test props for their motors you can run in a tank or while boat is tied off to dock or trailer to see if the motor can hit certain RPMS.
maybe you can have a Yamaha shop close to you test if they have the correct test prop
I spoke to a prop shop who said that for every pitch changed it will increases/decreases the the rpm by 200. So I bought and changed from a 19 to a 13 pitch prop. Tried out yestereday and hit my 6K rpm. I'm a happy camper...err boater .
