F30 Pilot air screw settings
  • F30 Pilot air screw settings
    Hi,
    I had a problem with an F30 rough idle.
    I removed and cleaned all three carburettors but I did not record the number of turns on the pilot screws prior to removal.
    I've balanced the butterflies on all three carburettors with a Morgan carb-tune kit which was not as difficult as I first thought.
    Motor now runs as sweet as a nut @900rpm
    Can anyone recommend a starting point from closed for the pilot screws
    I currently have them about 2 turns out?
    Orkney Mike
    What is the complete engine ID?
      Hi,
      Thanks for the prompt response.
      Details on my engine bracket:
      F30 AET 69 H/L 1002961
      69 H-DO
      22.1 - 84-90
      Mod: 05
      2004
      Orkney Mike
        For some reason my list does not include the F30. The F40 is two turns plus or minus a half turn in either direction so you may be within allowable tolerances. If the motor runs fine I would just leave well enough alone.
          HI,
          Thanks for the reply 2 turns out was not a bad guess then!
          Orkney Mike
