I've been trying to solve an issue with my power trim over the last few days; it will not trim up when underway. Here are the details:
I bought the boat last week and the previous owner had said that the pump motor was getting slow so he replaced the motor.
The motor will lift all the way up and go all the way down properly when on the trailer with the engine off.
It will go up down in the water with the engine idling.
It will go up and down in gear but only at idle speed.
Anything beyond idle speed and it will trim down only. The hydraulic system makes a straining sound when I try to trim up at anything above idle. The sound is the sound of a hydraulic system pushing against something that can't move in my opinion.
The boat is a 1977 Boston Whaler 13 Sport and the engine is a 1997 Dual carb Yamaha C40. The fluid level is correct and I had my 130 pound wife stand on the aftermarket hydro foil and it lifted her and the motor out of the water. (Engine off of course)
I need to stress that the system operates perfect in every way except when trying to trim up at just a bit past idle speed. Basically, put it in gear and it's fine- 16th of an inch past that and I get the straining sound.
I ordered the shop manual and am waiting on it. However, I've been studying the part blow up diagram and it seems that there are no replaceable check valves, only assemblies except maybe 3 thru 10
http://www.boats.net/parts/search/Ya...0PR/parts.html
It almost seems to me that once there is any pressure against the system, it is locking out. Being that it operates normally in certain circumstances, I think the electrical system and switches are fine. The pump motor sounds fine and is new, plus it works as described above. The lift cylinder itself could be suspect but usually they either work or don't. It should be easier to lift up at speed anyway. The valve body, in my opinion, is where the problem lies. But I have no experience with Yamaha engines so..... I have this question posted over in a Whaler forum as well but decided that a Yamaha specific forum might be more appropriate. Any ideas?
