Just picked up a used 2011 t60 to re-power my 17' Alii Kai. It came with a 703 control but the cables are too short for my boat. Have heard take meas. from control box to transom down the gunwale ,gunwale to centerline of motor @ transom,and transom to motor, then add 4 feet for cable length. Is that correct ? The existing (short) cables are disconnected from the motor and without ends . Would like to know the procedure for installing the new cables and the correct adjustment. Old cables are Volvo Penta Exact, grey throttle and black shift. I have the Control schematic from Boats.net to order the neccessary parts on the motor side. Are Teleflex Extreme cables the best bang for yer buck? Thanks
Control cable measurement ,installation and adjustment
How to Measure Teleflex Control Cables
Teleflex Extreme are good cables. Equivalent to Yamaha branded cables that are made by Teleflex for Yamaha. Whichever you can get for the best price is what I would go for.
2015_Yamaha_MRP
Thanks guys ! So when the new cables arrive, I just slap on the new ends, fasten them to the control box and motor,take up the slack ,and we're good to go.....right? Any other adjustments or tolerances apply here ?
Originally posted by bajakeith View Postblows away yammy cables
So, a Teleflex Extreme cable is great. But, a Teleflex Extreme cable with the Yamaha brand on it is not so great. Strange. I wonder why the branding is ruining the cable.
Ok,so can you give me the low down on how to adjust those puppies properly or possibly connect me with a link on how to ? Thanks bajakeith
cable adjustment
depending on the motor..put control in N,, the motor end in N adjust the cable end so it slides over the boss,,tempary put cotter pin in... run thru F/N/R then back to N,, spin prop...no clicks or any noise. then close throttle on motor and control in N and slide end over boss,,I/myself will turn throttle adj with a very slight preload towards idle stop.....easy to do but I cant type worth sh-t !! then put in F and the prop should solid lock up if you spin it backwards...
Thanks dude...once my parts arrive and I
I get around to wrenching,I'll let you know how it goes ! Much appreciated .
Installed cables and adjusted . Started motor and it idles at 700rpm on muffs. Sound about right ? When I raise the throttle lever to increase rpm, there's no increase until the lever is about 45 degrees from horizontal. Do I need to take some slack out of that cable ? Thanks everyone for all the expert advice !
Originally posted by boscoe99 View PostStrange that a Teleflex cable will blow away a Yam cable when the Yam cables are made by Teleflex.
Originally posted by b.quick8 View PostInstalled cables and adjusted . Started motor and it idles at 700rpm on muffs. Sound about right ? When I raise the throttle lever to increase rpm, there's no increase until the lever is about 45 degrees from horizontal. Do I need to take some slack out of that cable ? Thanks everyone for all the expert advice !
ÂÂÂÂÂÂÂ
