I have been dealing with a real doozy of a problem on my 1996 225STURU. Problem was first the fact that the motor would run great in the morning when we first fired it up. After running for about an hour or two, the motor would start to bog out when at WOT. We Rebuilt the carbs over the weekend...the bogging is gone. However a persistent problem is still there. I should have also mentioned it earlier. At low RPMS (say 1500-2500), it has this horrible shudder and literally shakes the boat. once you power it up, it goes away.
Could this be the knock sensor? What symptoms should I expect if the sensor is bad? I did test the sensor, but have some questions regarding it because the manual wasnt really clear on testing it. Manual says:
1. set your voltmeter to mV (millivolts).
2. hook one lead to the sensor wire
3. hook the other lead to the body of the sensor
4. tap the sensor with a screwdriver
5. (this part wasnt clear) Replace sensor if several millivolts (2-10 mV) are not displayed on the meter when tapping. Does that mean when I tap the sensor, the number should change? when hooking it up, the meter continually read around 2 mA. If I tapped it, nothing changed.
I am trying to isolate just exactly what is causing this problem because its really really bothering me at this point.
Thoughts?
Joe
Thoughts?
Joe
