90 2 stroke- overheat alarm-did the common
  • 90 2 stroke- overheat alarm-did the common
    Late 90's 90 2 stroke,
    Idle's fine,
    pee's good,
    throws overheat alarm when I run 3800 rpm for 10 min,
    Put new
    Impeller kit
    Thermostat
    Temp sending sensor/switch
    What do I try next
    most likely.
    now you get to pull the cyl head and cover.
    scrape out all the scale.
    reassemble.
