The boat is a twin rig
Engines are a pair of 3.4 litre Yamaha F250's model F250BET and FL 250 BET Serial numbers 6P2 X 1027357 G and 6P3 x 1013319
They were some of the first to have fly by wire.
When originally fitted we had round gauges.
The engines worked well for many years before we put on the shelves as 'spare engines'
We now have a requirement to bring these engines back into service and have placed on a boat. We fitted a newer control box, and new square gauges 2 x tachometer and fuel.
Initially there was no communication between control box and engines. The engines would not start. Eventually we fitted an older style control box which linked to a two switch keys witch panel (the older style, each engine on a separate key). We reset the control box via the Yamaha diagnostics.
The engines now start but we cannot get any information up on any of the gauges. Turn the keys on, we get the welcome to Yamaha initialisation on the gauges, you can quiz the gauges via the mode buttons but all gauges just show a flashing dash where the RPM should be. The trim indicators just flash at the lowest one bar.
With our Yamaha engineer we have scratched our heads but not been able to make any progress. Looking for ideas.
All wiring is sound - it's new
As we get the welcome initialisation and can quiz the gauges there is power to the gauges. It seems to be the gauges are not receiving a signal from the engine
Any ideas how to solve?
Tony
Tony
