Hi guys!
I've got a 2002 LF225 that was running pretty good and without any issues since I fixed it back in september until yesterday..
I went fishing yesterday..I drove to some of my spots, turned the engine off and drifted while fishing for groupers than moved to another spot and so on whilst always shutting off the engine when I got to the spots..
Anyways, about 2 or 3 miles out at about 5 or 6 knots and the engine stalled but I was able to turn the key off, set it in neutral and was able to restart it immediately after...
This happened about 4 or 5 times while fishing yesterday and I thought the main fuel tank was almost empty..after the 2nd time I switched to the 2nd tank and primed but it kept happening..
Just when we were picking up to back head back to the marina it stalled once more about 10seconds after I turned it on but it would not start again nor does the Trim work on both the 701 control box nor the engine...
I had to use the little backup engine the trustful 2-stroke 15HP Yamaha to get back to the marina... took me about two hours for a 15/20min drive...lol
Anyways.. I went back to the marina this morning with the multimeter and extra fuses but all the fuses check out ok and the battery is fully charged but still sprayed some electric contact cleaner and put in new fuses but nothing changed..
Before, with the ignition key on the ON position I would hear the fuel pump but now I don't hear the fuel pump working (I believe)...
The only thing "weird" is a buzzing from the main relay that I never heard before which probably was the reason I said "believe" I didn't hear the normal fuel pump noise..
SO, my question is: How do I test the main relay?
on mine it is written SN2210 1F29
It's the part #30 according to the Boats.net diagram
#30 RELAY ASSY 68V-81950-00-00
Any ideas?
Thanks in advance!
Vando
Any ideas?
Thanks in advance!
Vando
