Just purchased a used 2000 150 Yamaha OS 66 V Max
replaced all lower seals and replaced water pump,
water pump is going in the right direction but I am not getting no water through the head or through the tell tale. Engine buzzer going off
I only get water through the tell tale, when I use the Yamaha flush out attachment
no water exiting tell tale with earmuffs or engine sitting in a bucket of water
can anyone help with this issue,
Thank you,
Frank
Thank you,
Frank
