New here ,did a search on Harmonic Balances with NO results, Is anyone having problems and if so at how many hours
F150 Harmonic Balancers
Its under warranty even if past the warranty time. Yamaha will replace the assembly free of charge.
It doesn't take long, maybe 45 minutes for the replacement.
I don't know if they ever came up with the best design but it was updated several times. Mine was replaced with less than 100 hours on the engine.. I couldn't hear it but I was told it makes a different noise when failing..
The assembly is two shafts (very heavy duty, like small crankshafts) that reside right behind the fuel filter. Look at the front of your engine and you'll see the block. The two larger "bumps" are where the balancers reside. They replace that entire assembly.
Originally posted by TownsendsFJR1300 View PostIts under warranty even if past the warranty time. Yamaha will replace the assembly free of charge.
Many in Louisiana and other parts of the country are removing their balancer altogether. If it is not there is can't fail.
ÂÂ
