Gaskets required 1989 50hp
  • Gaskets required 1989 50hp
    Looking for gaskets for my 1989 2 cylinder 50hp (50CE 6F4) I can't match the model numbers on boats.net probably because the motor is European.
    J
    That hammer head (50Ce or Cm) 2 cyl just have been manufactured between 1981/83
    I belive if most parts donīt match with "later" 55 or enduro 48 / 55 must be very dificult get parts for it but contact your yamaha dealer as maybe he can get those parts.
    (I guess that even some parts for later 55 are getting dificult to get)
    All I can get is the 1978 60Ae 2 cyl and 1978 55Ae 2 cyl parts list (maybe some parts match, maybe not...)
      DIY Gasket
      if i were to make gaskets my self, is natural rubber the best material?
      areas to reseal.
      power head to exhaust - mid section to exhaust.
      Jimjam
        I would guess that any two stroke Yamaha base and exhaust manifold gasket will fit your motor. Same gasket has been used here in the states on all 40/50 two strokes from 1984 through the end of the last 40/50 two stroke that was offered here. At less than six bucks I would buy one and take a chance that it will fit.
        Don't think rubber will hold up to the temperatures.
        6H4-45113-A0-00 YAMAHA GASKET,UPPER CASIN
        1984 50ETLN Yamaha Outboard UPPER CASING Diagram and Parts
        6H4-41114-A0-00 YAMAHA GASKET,EXH.COVER
          thanks bosco
