This is beyond all possible explanations that I can come up with, so hopefully somebody else has some ideas. My boat sat outside over the winter and I just pulled it out to do an oil change for the summer. When I pulled the air intake assembly off of the throttle bodies, about a quart of fresh water dumped out of both of the lower throttle bodies. There was also a good bit of water that was sitting in the bottom of the air intake assembly. I don't know how it's even possible that water got there over the winter, but alas, there it was. Cowling was on and there weren't any floods! Luckily I had not tried starting the engine at all yet. I've sprayed a bunch of fogging oil into the cylinders, and with the spark plugs out, I've turned the engine over to shoot as much out of the cylinders as possible. I'm not sure water even got into the cylinders, possible it just pooled in the intake/throttle bodies? Beyond any ideas on how this happened, I'm wondering what my next step should be? Appreciate any help!
Water pooled in air intake and lower throttle bodies?? F200TXRC
The first - only - thing that comes to mind
is a problem with the interior of the cowling -
the inner "ceiling" of the engine top cowling -
and its water separator/drain system.
It has to let air in through that back 'scoop'
but water is supposed to be separated
and drained away through rubber hoses.
I can't really think of anything, else. I mean, what else could it be other than a pesky neighbor that doesn't like you
I guess just give the cowling a good goings over - maybe you'll even find a telltale staining of where/how the water got in. I've never looked closely enough at the drains/rubber hoses that Fairdeal mentioned, but that obviously seems like a good place to start - looking for clogs in the drain hoses... small leaves, etc.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Originally posted by DennisG01 View PostI can't really think of anything, else. I mean, what else could it be other than a pesky neighbor that doesn't like you
The sabotage idea crossed my mind too. I have no idea why anybody would sabotage it by putting water in the cylinders... that just seems like so much work for a person to do instead of just tearing stuff up if they were being malicious. I'm wondering if I should take it to the shop and go through insurance for it with this inexplicable possibility?
Aside from the reason though, I'd appreciate any feedback on what I should do now or check before attempting to start it.
Thanks!
Originally posted by 99yam40 View PostI would be changing the oil or at least check it for water.
is this motor run in fresh or saltwater?
I called my local shop today and they said at this point to just throw the spark plugs back in and see what happens. I decided to give it a go and it started up and sounded normal. I did find that it wasn't pumping water, so I'm taking the lower unit off next and I'm gong to do a compression test. The mystery of how the water got there remains though. I'd really like to come up with an explanation, so that this doesn't repeat itself.
Originally posted by 99yam40 View Postdid you run it with the cowling off to see if water was leaking into the lower cowling where is might get sucked into the intake if it got high enough?
I was just saying if the tell tail was not indicating water flow, it could have been dumping into the lower cowling instead of coming out where is should have been coming out
tell tails get pugged up all of the time., does not mean the pump is not pumping water
compressed air shot up it can move things around to clear it sometimesLast edited by 99yam40; 05-08-2021, 10:05 PM.
Originally posted by 99yam40 View PostI was just saying if the tell tail was not indicating water flow, it could have been dumping into the lower cowling instead of coming out where is should have been coming out
Â
