Tilt problem
  • Tilt problem
    When I turn on the ignition on my 70 hp the motor tilts up. The switch on the control handle works correctly. The pan switch works correctly. What could be causing the motor to tilt up when I turn the key to the on position?
    Disconnect one up/down switch at a time and try it. Start with the basic's first.
    Please post what you find and we'll go from there..
