I am a do it your selfer on my Yamaha 90 two stroke every year I like to change the lower unit lube, change the fuel filter and change the plugs. I have found that it is a real pain to find all of these part including required gaskets and Oring so am looking at developing a kit to include the following:
- Pennzoil High Viscosity lower unit gear lube 80W-90 (1 qt.)
- Shoreline lower unit lube Fill Pump
- Two Yamaha drain plug gaskets model 90430-08020-00
- Yamaha fuel filter element model 61N-24563-10-00 with genuine O-Ring gasket
- Three NGK B8HS-10 spark plugs
cost would be about $50-60
Was wondering if any of you other do it your selfers would mind giving me feedback on this? Something you would find useful? Anything about the kit you would add or remove? Attached is a photo of kit.
Any feedback would be appreciated and thanks for your time.
Tony
Tony
