200 HPDI Stuck in reverse
  • 200 HPDI Stuck in reverse
    2005 200 HPDI twins. I put boat in yesterday after a long winter storage. Engines run great but the starboard engine is stuck in reverse. If I move throttle to forward position with some RMP's the prop still goes reverse. When in neutral and give it throttle it too stays in reverse. Is this as simple as a linkage issue?
    you will have to look to see what moves and what does not when moving con*****er
      Thanks you.
