I replaced the impeller on my 1993 Yamaha 8HP outboard and notice water spitting/exhaust coming from the exterior hole on the front of the middle section, just above the lower unit where the shift shaft and its accordion boot enter it. Is that normal? I can provide a photo or video if that will help. Water pumping fine now from the telltale (pee) hole. Thanks!
1993 8HP Spitting Water and Exhaust Around Shift Shaft
I should have included this photo of the area where the shift shaft goes through the middle section. The exhaust comes out and water spits through the open hole surrounding the accordion boot. Trying to find out if this is configured correctly and whether this hole should be sealed somehow. Thanks for any help.
Originally posted by robert graham View PostDrop the lower unit and double check your assembly after water pump service....any rubber grommets missing or assembled wrong?...
ÂÂÂ
