86 150 carb drain screws
  • 86 150 carb drain screws
    I need to drain the carb bowls on this motor. It looks like the drain screws are on the bottom of the carbs although I don't see a drain screw specifically Identified on the exploded parts diagram. Others in the forum mention this procedure like it is a simple routine. Can I drain the carbs without removing them. Can I use the main jet port on the side to drain. Can someone help with how to drain the bowls. Thanks
