Yamaha wiring help
  • Yamaha wiring help
    Dear friends,
    I am new in this and I need help from professionals...I have Selva 25 Moray 4T and control unit 703 which is still not wired to the engine.
    On the engine I don't have trim and electric starter so I need explanation which other wires I need to connect to control box (switch off, contact, tachometer, oil warning....)
    Until now I just disconnect arm from Selva and unplug one white wire (switch off). Do I need to unplug other wires (which ones?) and to connect them with control box?
    I hope that Iam not to confusing .
    What is the complete model of the motor? Better still, what is the complete engine identity? It will begin with the number 6.
      Engine model
      On the plate I can see
      Selva Moray 25
      S/N 151745
      Max RPM 5500
      HP 25
      Kw 18.4
      M.Y. 06
      CE 2005
        Oh, now I see. The motor is a Selva brand. Never heard of that brand before. Another learning experience.
        I have no idea as to the wire colors that are used on a Selva model. I have no idea if it is compatible with a Yamaha brand 703 control box.
        The 703 control box comes in two versions. A seven pin version and a ten pin version. Don't know what you have. Anyway, here are the wire colors for the control box.
