Ive disconnected the two remotes on motor and on controls. Still will not shut off. Control stuck on up last fall and drained battery? What part do I need
1993 130HP Tilt trim up wont shut off
No one can know what part you need since no one knows at this time exactly what the problem is.
My guess would be that the contacts in a relay are stuck closed. But, it could be some other problem.
There is an up relay and a down relay. Which position is the motor in? Full up or full down?
Do you know where the relays are located? Do you know what they do? Would you know how to test them if a procedure was provided?
Here is a wiring diagram of the relays. Let us know if you feel like trouble shooting the system.
Items 10 and 11 in this illustration.
1993 130TLRR Yamaha Outboard ELECTRIC PARTS 2 Diagram and Parts
ÂÂ
